sergeauckland
Serge,
you didn't reply to my questions. You just regurgitated your views.
A valve amplifier designed to normal engineering standards, as opposed to one made to be a retro effects box, has not too much trouble. Ask Johnson, Beard, TdP, ... oh, Williamson, Walker, Leak, ...As for the speakers: think about the measurement methods available in 1968. How much inherent smoothing would have been going on back then?
Completely agree with the thrust of your arguement. Vintage valve amps and a few modern ones can indeed meet DIN 45-500. A few can be considered transparent in that they will most likely pass a SWBT. What gets me is that whilst a 50 year old Quad, or Leak or Williamson will pass, many modern ones won't. A few will, Mackintosh for example, but many more won't especially SETs.
One would have though (wouldn't one?) that after 50 + years, if one wanted to design a valve amplifier one could do a better job than those past manufacturers. Clearly not.
As to loudspeakers, I'm not sure of your meaning about smoothing.
Loudspeakers then were usually measured with a B&K pen recorder, where the writing speed determined the amount of smoothing. Using a slow sweep speed and a high pen speed, it was possible to capture a pretty much unsmoothed trace, just as now. Now of course, the software will apply as much or as little smoothing as needed for the purpose, third octave is a good compromise as it more or less stacks up with what we hear in terms of the energy contained in the peaks or troughs. For publicity /brochure purposes, octave smoothing can do wonders for a peaky loudspeaker.....
Looking at test reports as published in HFN or on Paul Miller's web site, too many modern loudspeakers seemingly make little attempt at a flat frequency response even with third-octave smoothing or accurate pair-matching. Many do of course, but like with valve amplifiers, where's the progress in accuracy over the years?
S.
