Mike Hanson
Trying to understand...
There's likely a minimum drop, but the whole point of the VBE is to regulate even lower. In the case of my Voyagers, I have a 50-0-50VAC transformer producing around ±70VDC into the VBE's input. It regulates it down to somewhere between ±50-55VDC, so it's dropping 15-20V. You'll have to ask Les whether dropping it this far is necessary/best.As you read through the threads you find the occasional contradictory statements. Do the VBE's drop 2 or 4V??
For example, the input stage of the NCC300 has built in regulation, and you adjust that to be 5V less than the input voltage. Having some headroom is a good thing when regulating voltage.
