Pete MB&D
Pete Maddex, the one and only!
Hi Pete,
I thought tap water was a no-no unless you have particularly soft water? I regularly rinse my black car with tap water after washing and the result is horrid. There is normally a grubby film that needs lots of work to remove. To think I've chucked that on my LP's would be a worry....
You might as well use tap water with the IPA if you have a clean supply?
In the Midlands the water isn't hard and the amount that gets left on to evaporate is negligible so it's not a problem depending on how OCD you are
Pete
