Marchbanks
Hat and Beard member
...the overall sound is breath-taking – like you’re sat in the recording booth with the musicians.
You cynic, you.
Do you think a company producing amps can sell them for £c4k on foo alone?
Would you order a steak in McDonalds?
Take a chill pill man. Some people are into edgy shit, n’shit.Edge W, what a shit name, looks shit as well. Four bags for that, no thanks.
They'll be the same circuitry used in their £500 amps but with bigger power supply, hopefully better quality components and a really fancy case... maybe some boutique capacitors etc...
Probably (I'm making some big assumptions here yes....) the same Doug Self designed bias displacement "blameless" amp circuitry used in earlier models and already well documented by Self as being as optimised as possible.... so what's got so much better to allow another zero on the price?
Not that the above necessarily means they either will or will not be competitive with other makes and models around the same price of course....
That's the same type of thing you said about the Tron Convergence which turned out to be totally incorrect.
