James Evans
Bedroom Bodger
Any chance you'd put the blackgate in the wrong way round? What voltage rating are they compared to the original caps? have you bought a multimeter yet?
To be honest Im not sure. The stock caps wer small rectangular grey things and I dont understand the writing on them. I guessed they were bipolar as there are no markings on the PCB. I studied the circuit to see which pad led to grond and fitted the BG's accordingly (I at leat I think I did, I might have got it wrong). The BG's I fitted were 16v rating (15v supply to this area of the circuit). Ive got the originals back in and everything is fine.
Still dont own a meter, shoot me! I WILL get one soon! HeHe!
The Jisbos has a fairly high current drain (30mA), so you need to make sure that the +/-15V suppy of the 340A can handle a pair of such hungry beasts.
It looks a perfectly reasonable circuit. Some of the parts (2SK170, 2SJ74) can be hard to get hold of.
My other concerns would be size (fairly big board, is there room for two?), and the very high loop gain, which can give all sorts of issues with RF stability. You would definitely want to have access to a scope and signal generator to make sure it was working right.
Got some 100uf Tants and 100uf Nichion muse caps on the way. Any advice where to use them?
