mikesnowdon
resU deretsigeR
A freind advised this little list, simmlar to what you said Dan:
*C4 C5 on U4 change to BG 16V 220uF (input selector chip)
*C25 C14 on U1 change to Mundorf MKP 2.2uF (signal path)
*U1 change to LM4562 (input buffer) optional.
*C7 C8 on U1 change to BG 16V 220uF (input buffer)
*C3 C37 on U7 U6 change tro Mundorf MKP 2.2uF (signal path)
*C40 C41 C42 C43 use a BG as large as can be fitted 35V+ (power chip local supply rail)
*C45 C46 change to something better again (like BG) 35V+ (20V rails before opamp regs)
*C49 C50 change to 25V BG 470uF or 1000uF (supply to opamps after regs)
*U8 U9 could do with upgrade (opamp regs)
C19 C29 change to Mundorf MKP 2.2uF (signal path)(tone bypass circuit)
I see the main differences are that you suggest bypassing C14, C25, C19, C29 with a wire link, and the above reccomends using Mundorf MKP's? I suppose if its OK to remove them then its better (and cheaper) to link them out?
