Clive
Thanks for the information regarding Ian Harrison, phoned him, reserved one, sent cheque.
Chiily
Your question Anyone recommend suitable hardware for fixing it on to a tonearm?
This thread was originated to discuss the need (or not) to tighten the mounting screws of a DL103 to excessive levels. Most people have indicated that as the body is plastic, it does not need to tightened to excessive levels.
I asked denon the question.
Good Afternoon
I have purchased a DL103 cartridge. Do you have precise instructions as to how much to tighten the mounting screws. As the cartridge is plastic bodied I am afraid I may over tighten it.
Frank
They replied as follows
Dear Sir
Thank you for your e-mail regarding Denon products.
We would recommend that the securing screws on the DL-103 should be tightened just a little more that finger tight.
Regards
Product Support
KP
This is an e-mail from Hayden Laboratories Limited, registered number
801901. The contents of this e-mail are confidential to the ordinary
user of the e-mail address to which it was addressed. No one else may
copy or forward all or any of it in any form. Our postal address is
Chiltern Hill, Chalfont St Peter, Gerrards Cross, Bucks SL9 9UG. If you
receive this e-mail in error, we should be obliged if you would
telephone our Administrator on 01753 888447, or e-mail
[email protected], and then ensure that you delete this
message immediately. We do not accept any liability or responsibility
for: (1) changes made to this e-mail after it was sent, or (2) viruses
transmitted through this e-mail or any attachment. Thank you. C Hayden
Laboratories Limited 2002
-----Original Message-----
[email protected]]
Sent: 22 October 2003 14:03
To: Pro
Subject: FW: Contact form Denon
USE THE HARDWARE SUPPLIED. I WOULD (WILL)
Fatcat
