Hey guys, remember: the signal is AC. There is no 'upstream' or 'downstream'. For example, playing a sinusoidal tone, the current would move one direction half of the time and the other direction the other half. Directional speaker wire and interconnects make...absolutely no sense!!1!
True, but if the manufacturer believes otherwise, why wouldn't you just hook it up as the arrows indicate? Surely you've nothing to lose.
Thought in AC the electrons flow backwards..?
Or they don't buy cables with arrows because the BS detectors go off when they see them.I guarantee that all the impossible/ignore it members would connect it the way the manufacturer intended.
Well, @Rug Doc ripped a car apart to 'fix' them, so he lost a few hours I'm guessing.True, but if the manufacturer believes otherwise, why wouldn't you just hook it up as the arrows indicate? Surely you've nothing to lose.
