I go down the local church and pick up some holy water.
Are you claiming that the Audio Systeme or Humminguru sufficiently clean LPs better than a vacuum RCM to such an affect that the results are audible?
Yes, significantly.
Make friends with your local coffee enthusiast that uses reverse osmosis to protect his equipment against limescale build up and so on, if you were near me I would let you take some when you needed it. Hopefully the technically clued up folk such as DV don’t disagree.So what’s the best water to use on an RCM. Got a Project VCE on the way and wondering what water to purchase to use with the supplied concentrate?
Bit confused by distilled, demineralised, deionised, pure, etc.
Dealer said just go to Halfords. Mate said go to the chemist.
What’d all reckon?
Heavy water (2/H2) is clearly superior to most of the competitors.
Every time I dip into one of these threads I remember how lucky I am not to have an RCM ;-)
We will see how long I’m a member for…
Sorry, Jesmond, it's for life. Once joined, you live in an eternal vacuum whilst you have vinyl. Don't forget the new sleeves though; poly paper of Nagaoka type. Both have their pros and cons but new sleeving is essential to an RCM existence
Have a load of the clear Nagaoka ones from years ago but I hate the things!
tried some once,gave myself a nasty burn when I spilled some on my armI go down the local church and pick up some holy water.
Thanks for all the replies to my OP.
Not used the Project RCM yet, but note in the instructions it says to warm up the "Wash-it" concentrate for the water. Presume that actually means warm up the mixed cleaning solution? And how warm is warm? Don't want to damage the records!
