per flemming
Registered User
Bottom Line:
Avoid any with cabinets made from wood or its derivatives.
Thats quite a statement Les
sure this will leave 99%+ out
Maybe a list of the remaining are in order
Bottom Line:
Yes they were good; quite well balanced on sax, without emphasising the bright edge or taking it off. I'm used to a chestier and slightly darker coloration on the Harbeths with tenor. It's a slight emphasis which I find addictive. But the weakness of the Harbeths is the upper ranges of the soprano. The 63s were definitely superior here. I think what you've said about the problems with crossovers comes into play here, since there must be something going on in the harmonics of the soprano sax that is not served well by a lot of the two way speakers I've heard. (on the other hand the Harbeth Monitor 30.1 is very good with soprano sax, so the tweeter is crucial)
Also the Quads were better with the trumpet. That Miles track that I'm obsessed with - 'Mood' on ESP - it's very difficult to do that without screeching and the inner part of the trumpet sounding thin. The 63s did a pretty good job of it. They didn't approach the miracle I've heard on my friend's Devores, but that was only when he was using super-tweeters, and we were listening to the vinyl on his Hyperspace, and many other factors.
With piano I thought they were really good, ever after a very brief moment of the Boulez piano sonata.
Thanks for your pointer on Quads Tony - your intuition was good.
Not trying to cause a row here, but what do super tweeters in conjunction with a vinyl source bring to the party?
There's 2/3rds of SFA coming off vinyl at 16Khz, let alone in the supertweeter range, surely?
Given the none-linear response of the human ear, wouldn't the ideal speaker slightly boost bass at low levels, to give the perception of a more linear sound? You know, the old 'loudness control'. it's maybe not so daft.
Good to meet Andrew and glad he might be on the way to a solution.
Some great music played
Re low bass, that's going to vary significantly between rooms and positioning but at least there's room for experiment. I get -6db at 35Hz which does me fine and no particular peaking, unlike with box loudspeakers in the same room.
ESLs (57 & 63) display a little LF shelf boost when used in smallish rooms, so at low listening levels you effectively have this effect built in when running the pre amp flat.
For louder listening I switch in 3dB of shelf cut cornered at 170hz, which actually puts the response back to flat and better suits louder listening.
As a young chap new to hi-fi who visited me for a bake-off last weekend commented, 'wow, you can do that on the pre amp? - why don't more pre amps do this?'
Quite
