AT150 SA = VM750 SH
They sound the same to me anyway.
I have a 540 on my Dual 1229 and really enjoy it, but I chose a VM95SH for my TD160/tp16 since it's a lower compliance cart which I thought would be a better mate to the higher mass of the tp16 (higher mass relative to the low mass Dual arm). The 540/740 is high compliance -- do you think it's a good match for the medium mass tp16? If so I'd love to try it on the thorens.My favourite AT MM cartridge is the 740 ML over the 750 SH.
The 740 is a posher, lusher 540. I have both and the 740 is a little better at imaging and brighter (and nicer looking, but that red stylus support is not so nice ).
It works incredibly well on an old Thorens TP16, as an aside – ideal for those who have a TD126 for example.
It also works really nicely on Dual ULM tonearms – but so does the AT-VM95!
A bit surprised your ranking 520EB over 95SH.
I run a 95SH, maybe I should try a 5xx or 7xx .. but was about to order a AT150SA
Yes, by all means do try it!I have a 540 on my Dual 1229 and really enjoy it, but I chose a VM95SH for my TD160/tp16 since it's a lower compliance cart which I thought would be a better mate to the higher mass of the tp16 (higher mass relative to the low mass Dual arm). The 540/740 is high compliance -- do you think it's a good match for the medium mass tp16? If so I'd love to try it on the thorens.
I'm curious as to how you managed to get VM95 mounted to TP-16. Is it a TP-60 headshell (i.e. TP-16 MkI tonearm)?I have a 540 on my Dual 1229 and really enjoy it, but I chose a VM95SH for my TD160/tp16 since it's a lower compliance cart which I thought would be a better mate to the higher mass of the tp16 (higher mass relative to the low mass Dual arm). The 540/740 is high compliance -- do you think it's a good match for the medium mass tp16? If so I'd love to try it on the thorens.
Thanks for the info regarding compliance.I'm curious as to how you managed to get VM95 mounted to TP-16. Is it a TP-60 headshell (i.e. TP-16 MkI tonearm)?
When TD-160C was released, Thorens made a big deal about the TP-16 (MkI) tonearm being suitable for high compliance cartridges with 'ultra low tracking force'. IME, high-compliance cartridge compatibility can be as much down to bearing quality/friction levels as it is to tonearm effective mass vs. cartridge compliance/weight. The general consensus is that the effective mass of TP-16 MkI is 16.5g, however, mass distribution also plays a large part here. For example, a much heavier cartridge than the plastic mounting plate VM models will have the standard counterweight much further out from the bearings (i.e. moment of inertia involves both ends). Regardless, I've run everything from Ortofon MC20 through to über-high compliance 70s MMs on TP-16 with superb results. Keep in mind that VM540ML is only 6.4g, even less with the flip-down stylus guard removed.
Your TD160 appears to be in really nice condition.Thanks for the info regarding compliance.
Yes, I’m using the TP-60 headshell with the VM95. When I was researching carts for the TD160, I read many posts saying that the VM95 can’t be mounted to the TP-60 without mods, but the only thing I had to do to make it work was use different screws. I planned on getting an after-market headshell for the TP16 (there are a couple compatible headshells available that allow for top-mounting carts), but there was no need as the VM95 mounted to the stock headshell as easy as any cart I’ve ever installed. It sounds incredible for a $200 cartridge on the Thorens. I ran several decent mid-level carts on my Rega RP3 including an AT 150MLX, Hana SL, and Rega Ania, but the VM95 on the TD160 sounds better to me than any of these carts did on the Rega. I’m not saying the VM95 is better than those other carts, just that its combination with the TD160 is superior to those carts with the RP3 to my ears (and the RP3 was upgraded with Groovetracer subplatter and delrin patter, and TTPSU).
Thanks! I was fortunate to find one in such good condition. I can't remember for sure if those are the screws that came with the headshell but you're probably right about that.Your TD160 appears to be in really nice condition.
I assume that you used the original Thorens M2 headshell screws, and managed to have them not engage the captive M2.6 threaded inserts within the VM95 cartridge body.
This is of interest to me as I have a minty TD-166 MkII with TP-11 Mk III here that takes the same M2 screws, albeit threaded into holes within the finger lift from below, in this case.
Your headshell certainly appears to be stock. There is a 2 x M2 threaded metal plate that sits within a slotted recess in the headshell casting, with the stick-on Thorens label holding this captive. Both the threaded plate and label used to be available as parts should one or both of the threads have become stripped.Thanks! I was fortunate to find one in such good condition. I can't remember for sure if those are the screws that came with the headshell but you're probably right about that.
