gustav_errata
When listening to a single speaker it is easier to check for correct tonality as a stereo image can obfuscate errors.
I thought that's what the measurements are for.
The portable Hugo 2. According to Chord the Hugo 2 can accept M Scaler's 768Hz output over dual-BNC, presumably with an adaptor cable?Do you mean he received a TT2 and Scaler or a Hugo 2 and Scaler, I assume they mean the TT2? To make the most of the Scaler you need a dual BNC DAC - TT2 or DAVE.
Below TT2 the only current/legacy Chord DAC with proper 2 x BNC is the Qutest afaik. The newest Hugo only has a Mini Coax. You can get a cable from the likes of Vertere for a couple £hunded. 3.5mm specially configured at the tip end to Y shaped Phono with a couple of BNC adapters, gives 2x384, ‘tis a bit convoluted and not a setup I tried out, pretty much a unicorn cable, I preferred going with Mojo for ‘phones and Qutest in the rack.According to Chord the Hugo 2 can accept M Scaler's 768Hz output over dual-BNC, presumably with an adaptor cable?
https://chordelectronics.co.uk/product/hugo-mscaler
Asking PQ of Audio Note UK to review the latest Topping DAC would seem equally unlikely to have a happy outcome.
It depends what you want to achieve and what ASR wants to achieve. These are not necessarily the same.For Home Hi Fi don’t designers take into account the fact they will be sold/used as a pair in a typical living room and aim at that as a target environment. I can see the sense for a studio/musician application of gear sold in Pro Audio Shops in the test but not for gear typically sold in 7oaks/Richer etc.
Now there’s a sweeping statement if ever there was one. Would you care to develop your argument?
Arrant nonsense.
Yeh, really, how many gigs and concerts do you go to a month?
An electrical component is defined by its measurements.
Keith
ASR separates the actual measured performance from the marketing.
Keith
ASR is the marketing arm of Schenzen Audio, makers of Topping and other brands from the same warehouse.
ASR is the marketing arm of Schenzen Audio, makers of Topping and other brands from the same warehouse. They send ASR stuff and on or around launch date he publishes a rave review. He did this the other day, even though a load of people pointed out that the amplifier completely failed to meet its specification and the marketing was completely dishonest. He was challenged on this, I think by a member who is a UK manufacturer, and amir/ASR struck his head in the sand and has not responded.
That said, it's the canine's testicles for amusement value.
Not it is not, however if you have any evidence for this I suggest you post it
I was trying to make a polite reference to "the dog's bollocks". I assumed this forum has an uncouth language filter. Obviously not, plus I just mentioned Trump and that got through as well.Well, the word "Bollocks" does spring to mind.
You must be one of the ASR types because they always ask for evidence. I've looked at a couple of items, one was a Topping amplifier that they were making crazy claims about reinventing amplifiers, ASR was sent a pre-release version and the review came out on the same day as a coordinated launch with Topping and some other sites that do the same thing. Surprise-surprise, the review featured on Topping's website.
One may not like the presentational style of ASR, but the basic rigour and scientific numbers are presented openly and methods clearly defined.
I don't see why ASR can't criticise poor noise, channel imbalance, distortion or weird frequency responses. It's a discussion of the data from the output.
