ex brickie
So does that work properly with Linn Saras Andrew?Here you go:-
Oh yes!So does that work properly with Linn Saras Andrew?
Obviously 5WPC would usually be more than enough to reproduce a harpsichord at realistic level whilst worst case would be heavily compressed music close to clipping.
Oh yes!
320W into 2ohm
I had the same problem during the summer months. Feeding a pair of “Old Linn speakers” . Solution……..A pair of 135s
To be fair, for twice the price you do get two boxes . But I won’t argue with anyone about what sounds best, it’s subjective and personal to us all. However, I can’t quite work out which of the three amps you have actually heard. Personally I loved my 250, the 135s more but the 105s I’ve never heard. From what I’ve been told though, they do sound very Naimish.They were twice the price of the 250 for fractionally more power, never saw the attraction. The 105s are cheaper than a 250, about 40% more power and from what I've been told sound better than the 135s!
I have an ATC all in one CD/DAC/amp (SIACD) which runs quite hot with my Boenicke speakers . Boenickes are known to be a trickier load - sometimes dipping below 4ohms.
I’ve only listened at fairly low volumes and the amp hasn’t shown signs of cutting out yet (it has a thermal switch) . But I may want to turn it up occasionally
My understanding was that ATC make amps that are very durable even under a bit of stress? The manual doesn’t specify that only 4-8 ohm speakers can be used
Just in case, what makes/models are out there that are very reliable under a difficult speaker load?
I only know of Linn Klout or LK280 used to drive very difficult Linn Saras
Has to be in a £1k to 1.5k ish second hand price range .
I might be worrying unnecessarily of course! If there are ATC amp users out there they might be able to help!
Multiple pairs of output devices, plenty of heatsinking and power into 8R kept reasonably low are the things to look for in an amp to drive low impedance's safely.
That’s an interesting point Jez about 8R power kept reasonably low, never heard of that before. I’ve noticed Mark Levinson amps tend to be rated quite low for their given size, e.g. 100WPC for something reasonably massive but tend to almost most double their power into 4 ohms.
IIRC the 25wpc ML2 will do about 100wpc into 2R. The high voltages required to give 200WPC+ into 8R puts the output transistors under a lot of stress when giving the currents required to drive <4R loads, much more so with particularly awkward low impedance loads with big phase angles.
Has it blown up yet?
If an amplifier is working hard it can get hot. It's not a fault, it's a characteristic. My NAP250 used to shut down regularly and get so hot you couldn't keep your hand on the top. My Meridian 105s also get very hot at high volume and shut down occasionally, they're more powerful so much less often. No damage is done, they're designed to do this.
ACT build studio gear, so it's tough. I'd be very surprised if your amp wasn't totally fine with running hot and has a thermal trip to protect it.
And 4ohms is not that bad. Old Linn speakers can drop to two.
Naim pricing is a fairy tail for grownups. The 135 is basically a 250 with a channel removed. Ok, some other small tweaks but not much. The 180 and 250 are the same except for one small circuit board and the price difference was how much?
Yes, the 105s sound very like Naim. If you like one you'll like the other. I certainly have no regrets. I've never owned 135s but it was a while after I bought the 105s I was talking to a guy who ran a six-pack of four 135s and two 105s and he said the 105s were the better sounding amp. I've since heard the same opinion from a couple of other people.
