laverda
Do you still use it? I have one that I've loaned to a friend. I may have to get it back.
Are all the outputs rated the same?
Are there any pics of the inside available?
Yes, mine is in use every day.
I have one that I've loaned to a friend. I may have to get it back. You have a James Audio? Id get it back and take the lid off, when you do you will be surprised at the size of the isolation transformer 2.2kVA IIRC which is lifted off the case work by 'Paxolin' spacers, it also protected by thermistors attached via s/s straps and in series with the filtered mains.
Each outlet has a large CRC network which reduce in size from outlet 1 - 6. or 6 - 1 cant remember now.
Total output should not exceed 600watts & no more than 250watts with Class A amplifiers. I can confirm the Class A max... as it in my case it popped the output fuse 6.15A(T) 250v when driving two 100watt Class A Pass Lab amps.
NB. Some years ago I did audition a ISOTEK conditioner (cant remember the model) thinking that 'tech' had made good advances, it hadn't and glad I didn't need to shell out for a new 'modern mains conditioner'.
I'm amazed at what's in a modern conditioner...for the money.
Are all the outputs rated the same? No.
