Chaps, I've come to the conclusion that my iMac is very noisey and I'd like to do something about it.
A few questions..
In the past I have used a mains conditioner that had 19uF of blue Epcos Polyprop caps between Line and Earth and again between Neutral / Earth.
Is there a limit to the capacitance amount?
I understand that any cap must be 'X2' rated, ie guaranteed to break 'open' at mains voltage. The caps used must also have absolutely minimal leakage.
Is the X2 rating equivalent to the VDE rating? Are they both safe for UK mains use? -VDE regs appear to be very lengthy.
Assuming that I use a properly rated cap, then is there a different limit if it's across the Live/ Neutral, rather than as above?
Can I just use a washing machine starter cap in this application? Ie 50uF or so of very low leakage polyprop?
For a RC filter I should combine this shunt cap with a series resistor, 25W, 0R3 WW or similar and use a suitably large bleed resistor to keep it safe after shut down.
Many thanks for your help
A few questions..
