The iTunes interface is of poorer sq allegedly.
So many assert.
Watch out - Amarra fresh out the packet sets its equalizer to default which is close to its bass booster setting. Select off on the equalizer to get back to a flat response.
One of the reasons I mentioned Amarra is that you can if you wish use the iTunes interface. However one of the reasons I chose it is that I can't stand iTunes!
Amarra is also a professional solution used by recording studios so if the music sounds bad with this player then the fault lies elsewhere in the OPs system.
Cheers,
DV
There is no reverb setting in Amarra.It was set to "off" on the trial download. However what I need to find is how to turn off the reverberation, which I could not find in admittedly just a few minutes playing with it earlier this evening. I will also need to try Amarra on a better recording. I was playing volume one of the complete Beethoven sonatas played by Daniel Barenboim, made at Abbey Road in 1962. Not very well recorded and it sounds like he was having to play the beat up old studio Steinway as it goes a bit honky tonk on some notes. A pity about sound quality and piano because of all the times he has recorded these sonatas, I think his piano playing was at his very best on these recordings.
But it won't play Flac![]()
Not the up-rezzing, from 44/16 to 96/24 which is being done by the audio chips on the main board.
Are you sure about this? Mac OS X has a Core Audio subsystem which provides several layers of hardware abstraction. Most of the specialist players like Amarra and Audirvana can be configured to bypass some if not all of these layers, but I am fairly certain that iTunes relies on Core Audio quite heavily.
There is an inexpensive app available on the Mac app store called BitPerfect, which can be configured to automatically switch the Mac's output to match the content's native sample rate. This effectively sidesteps the Core Audio resampling. It is discrete (a toolbar icon is all you see during normal operation) and it plays nicely with iTunes.
What playback software are you using on the Mini? try Audirvana+ this automaticaly sets the output to the same resolution that media was recorded at. There is no point in setting the Macs output to 24/192 or whatever if the material is recorded at 16/44.
it does if you want to over sample, which IME brings a smoother sound. not to my taste but many do it.
If upsampling like this brings a "smoother sound" I'd be worried that something was wrong with either the source material or the DAC. The implied alternative is that you prefer the sound being altered for some reason.
