wilsonlaidlaw
When I came back from my French house this year, I brought the new Benchmark DAC-2L I had bought there back with me. I am streaming from a 2011 Mac Mini via USB, mostly from ALAC files uploaded from CD's. I used to do this to my previous M-DAC (now on my bedroom system) via an M2Tech Hiface 2 re-clocker but given the DAC-2L's asynchronous Ultra-Lock 2 system, the Hiface should not be necessary. The DAC then connects via XLR cables to a Krell Vanguard Integrated amp and then to ATC SCM19 Mk.1 speakers plus an ATC powered C1 sub woofer. My set up in France is not wildly different except in a much bigger room, I am using Krell Evolution pre-amp and Krell Evo 2250 power amp to the larger ATC SCM40 Mk.2 speakers with a Monitor Audio Gold 15" powered sub. The Mk.2 ATC speakers are noticeably gentler and less painfully bright than the Mk.1 versions.
I normally have the Mac Mini set to output on USB 2.1 to the DAC-2L at 192kHz/24 bit. Since coming back to the UK, I notice, particularly for solo classical piano music, that it sounds better, smoother and less over-bright/harsh with the output set to 96kHz/24 bit than 192kHz/24bit. It has been suggested to me that the Mac Mini's audio chips, which I think are Intel on the main board, can really struggle with 192 kHz and will produce artefacts, which make the music sound odd and unpleasant. In the UK I am in a much smaller room, closer to the ATC Mk1 speakers, so I may just be noticing what was always there at 192kHz but the brighter speakers just make it more apparent, together with being a lot closer to the firing line.
Thoughts folks?
Thoughts folks?
