It would depend on the frequency of the feedback, and the isolation frequency of the feet. The weight of the the TT would also affect that.Yesterday, in a big DIY shop, I saw sets of 4 round pieces of hard-ish foam rubber, about 10cm diameter, for putting under the feet of washing machines. They cost about 8 euro. Maybe they would work?
The Lenco sits on a large and heavy purpose built plinth designed for its 12 inch arm. It had been on 3 spikes and housed in a largish cupboard. The speakers are only 8 inches from the speakers. The spikes, I think, acted to link the t/t to the cabinet and this then through to the floor. Speaker vibration either through the air or through the floor I'm pretty sure caused the problem. It could well have been a certain frequency that triggered the feedback as has been suggested. Also, I bought some washing machine feet which turned out to be quite rigid and I suspect would have behaved in a similar way to the spikes. The softer (though not too soft) pipe insulation solution allows only a small amount of suspension. This appears to have done the trick.It's an interesting thread. My Lenco turntable is right next to one of my reasonably large speakers (Altecs with a 12" driver) - literally a 3cm gap - but I've never experienced feedback. I don't use any sort of isolation, the deck is just plonked on a teak sideboard. Perhaps being in a heavy plinth helps? Or perhaps I just don't play music as loud as the OP? : )
That sounds plausible. As Tony posted it could have just been a single frequency perhaps exacerbated by room modes. Glad it's all sorted.The Lenco sits on a large and heavy purpose built plinth designed for its 12 inch arm. It had been on 3 spikes and housed in a largish cupboard. The speakers are only 8 inches from the speakers. The spikes, I think, acted to link the t/t to the cabinet and this then through to the floor. Speaker vibration either through the air or through the floor I'm pretty sure caused the problem. It could well have been a certain frequency that triggered the feedback as has been suggested. Also, I bought some washing machine feet which turned out to be quite rigid and I suspect would have behaved in a similar way to the spikes. The softer (though not too soft) pipe insulation solution allows only a small amount of suspension. This appears to have done the trick.
