Alan McClymont
AMCC
I tend not to crank up the volume too much as a rule. However, when the neighbours are out and the mood takes me it's good to have a bit of a blast.
I have an issue when playing vinyl when above moderate listening where I get what I can best describe as feedback - a deep humming which, once it has begun, only disappears when then the volume is reduced. The hum is not present using digital source. Also, using analogue input the volume can be raised to near max when the cartridge is not in contact with the record. Of course this is of no use at all to play vinyl but it does lead me to suspect the issue is with vibration rather than earth loop type problems. Speakers are stand mounts (10 inch bass units) on a wooden carpeted floor.
So the question is do I attempt to isolate the turntable from the rack or isolate the speakers from the wooden floor. If the answer is both, can anyone suggest a cost effective isolation solution?
Thanks,
Alan
Thanks,
Alan
