Tonearm cable recommendations.
Discussion in 'audio' started by early, Sep 23, 2017.
  1. early
    early pfm Member
    Hi folks,
    I need a tonearm cable that has very good shielding, my current Van Damme cable picks up rfi and it's starting to drive me nuts.
    Can anyone recommend anything?.
  2. Tony L
    Tony L Administrator
    I use vdH and like it as it tends to be very well screened and very low capacitance so MM cart friendly. I use a SME made vdH 501 Hybrid on my 124/3009 and like it a lot. I shouldn’t spam-up the thread, but I do have some vdH Wave going spare which makes for a nice tonearm cable if 80cm is long enough for you and you like bright green.
  3. Shuggie
    Shuggie Trade: Ammonite Audio
    Van Damme cable is as well screened as anything. Has it been correctly terminated.
  4. early
    early pfm Member
    Yes, I've taken it off the tt and checked. Screens are tied to the din connector side and ground wire. The screen is left floating at the rca side.
    The screening isn't that great on the Van Damme's, something like Tony's VDH Wave suggestion would be much better with its three screens.
  5. early
    early pfm Member
    Thanks Tony but 80cm would be a bit tight. Does anyone sell this stuff by the metre?.
  6. early
    early pfm Member
    Just thought I'd update this , you never know it may help someone else .
    I bought a Oyaide PA-2075 tonearm cable and this has total eradicated all the airborne rfi
    I was getting . It is worth mentioning that it is quite stiff , it wouldn't suit a sprung deck .
  7. early
    early pfm Member
