Tony L
Administrator
How about the decoupling mountings used by KEF and other on some of their drive units. I wonder is this would make a difference.
I suppose in the LS3/5a there is a bit of decoupling of the B110 from the baffle by the PVC U shaped gasket.
Tannoys up to the first version of the HPD were all designed for rear-mounting to the baffle, so the front of the driver basket has quite a thick felt or foam rubber gasket depending on model. When fitting a pair of Golds that have sat out of the cabs for a while the foam gasket reverts to being a good few mm thick and they actually take some time to bolt down again, i.e. they already have this type of arrangement.
