removing gloss paint from vinyl?
Discussion in 'music' started by paulfromcamden, Apr 11, 2012.
  1. paulfromcamden
    paulfromcamden Baffled
    Hmm. Any suggestions?
    I have an LP with a 10mm blob of white gloss paint firmly bonded to track three :-(
  2. Anex
    Anex Señor Member
    Can't you fingernail it off? I'd guess most things which will thin the paint will also thin the vinyl.
  3. kjb
    kjb Losing my edge
    Thinking laterally:
    Splatter more paint on it, create a Squire-esque art work, frame it and flog it for £50 and buy a new copy out of the profit?
    What is the record?
    Kevin
  4. paulfromcamden
    Won't fingernail - it's well and truly stuck :-(
    It's this.
    Great record! I think it came out of a bargain bin years ago (because of the paint splash...) - I guess I'll either have to invest in a new copy or just stick to side b!
  5. ian r
    ian r 401's Nakman
    Looks like a Dada Disk to me - remove paint loose point
    for example
  6. Pete the Feet
    Pete the Feet pfm Member
    Judging by the cover it could be one of Fox's.
  7. Anex
    Anex Señor Member
    Paul, have you tried a sewing needle on it? You might be able to lever it off or poke it to death.
    I haven't listened to that in ages.
  8. Pete MB&D
    Hi,
    Soak it in white sprit to soften the paint, check that it dosn't do any thing to the record first!
    Pete
  9. Mescalito
    Mescalito pfm Member
    White spirit won't touch vinyl. It may strip out some of the plasticisers, but that shouldn't effect SQ.
    Avoid acetone or any of the cyclic solvents, though.
    If you have an already knackerd disc, try doing a trial with xylene. It will be borderline, but it shouldn't effect vinyl, but it will definitely soften alkyds or emulsions.
    Chris
  10. pil
    pil pfm Member
    Yes try white spirit on an old shagged record first.
  11. demotivated
    demotivated pfm Member
    could you epoxy or superglue an anchor point to the paint and then lever it off? A small bolt-head, flat glued on, could be grabbed by pliers on the threads of the bolt. Lever sideways so it yields.
  12. Pete MB&D
    Then we get a thread about removing epoxy from records:D
    Pete
  13. Mescalito
    In the case of aged alkyds, their adhesive strength to the vinyl is likely to be greater than their internal cohesive strength.
    This beinn the case, the paint spot would fail cohesively, leaving paint on the bolt head, but also still on the vinyl.
    Chris
  14. johnfromnorwich
    johnfromnorwich even my wife noticed the dif..
    If all else fails, it's been reissued. Nice weighty flat and quiet vinyl with extras on a second disc. Not quite the same I realise, but it's a corker.
  15. Linn Naim
    Linn Naim pfm Member
    Try neat IPA?
  16. Pete MB&D
  17. MartinC
    MartinC pfm Member
    Waste of good beer :D. If it's a latex (water) based gloss, use an ammonia based cleaner (Windex in the US, not sure of a UK version). That should attack the latex but not the vinyl. If it's an oil based paint try turpentine (but use on an old scratched throw away record to check first)
  18. Gaius
    A cunning plan indeed!
