GreatNorthWood
Canon EOS 350D
or . . .
OLYMPUS E500
What's it to be?
or . . .
OLYMPUS E500
What's it to be?
Unless must have a 'must have' function that only exists in brand x then the idea of selecting the lens or system of lenses that meet your needs may well be the way to go.If you no existing lenses then you can choose whichever suits you best
GreatNorthWood said:Canon EOS 350D
or . . .
OLYMPUS E500
The only downside is if you take a lot of wide angle shots. Your existing 28mm on a DSLR is the equivalent of a 45mm unless the camera has a full frame sensor. Of course, it does mean your 300mm effectively becomes 480mm.auric said:Having existing lenses that will work with the new body does lower the cost of a new system
