iansr
John
So if you need 2 outputs (say beacause you want to run a sub) what is the best option - just split the balanced outputs?
Alternatively, how about if you want to run multiple subs and use a miniDSP 2x4HD for bass management. Presumably you could utilise one of the digital outputs and connect it to the miniDSP whilst using the XLRs for your main speakers? Is it possible that the latency of the MDAC2 and miniDSP would be so different that the timing of the bass would be out of sync?
JohnUsing Balanced and unbalanced outputs at the same time is not a great idea as this unbalances the balanced outputs due to the extra loading of the RCA cable on one phase of the balanced output stage.
Its strongly not recommended for the DD2A designs but "workable" with the more standard designs.
