misterdog
Not the canine kind
My purpose is to wash the cover as it feels dirty. Merely wiping it just makes it worse!
Bruce
There is a coating on the remote giving it a non slip property.
It may not be dirt but just how it's meant to be.
Bruce
Contact cleaner would strip the coating - where are you located? I could try and source you a replacement handset.
Bruce,
No problem, when I next order salvaged MDAC's or MB's for the VFET amps from IAG I'll ask for a couple of spare handsets and post one to you
Bruce,Oh, bother. I'm in Singapore. Thank you John.
John,For the next week, I'm working on the lab before the weather sets in - I need to install the wiring for the lab, Power, Network, security system, Lab reference clock etc.. Once I've completed installing the wiring and other systems, then I can leave the work to the builders - and get back to the MDAC2.
I'll be more active here by the end of the week.
Today, the VFET MB donor units arrived - and they take up some serious storage space!
Also, the recently ordered salvaged MDACs - and my new curve tracer arrived so that I can fully characterise the VFETs.
I quickly dissembled an MB to refresh my memory - and its its going to workout better then I expected - I can have a serious PSU on one side of the chassis - with the Power stage on the other (with local PSU decoupling).... I can also salvage a few more components then I expected.
The VFET AMP is going to be stunning!
I'll post pictures later on in the week, once I have a few moments to spare.
John,
Will you reuse the transformers?
I read here that it was where Audiolab had scaled down the performance of the MB8200 compared to the Tag Mclaren 250MR. 380VA vs 650VA.
Surely the size of the transformer is related to the circuit design.
The biggest transformer in the world does not make for the best amplifier, if coupled to a crap circuit design.
I am aware of the obvious, but it does have an influence on the current the amp can provide.
I know but it is the MB8200 that has the smaller transformer. And you can read that the MB8200 and Tag Mclaren share the same design.John has based his design to suit the MB8200 not the Tag Mclaren.
Will the XLR connection of the mdac2 be superior to the RCA or is there also a benefit of the new output stage for the RCA?
Would you recommend a XLR-RCA converter?
Hi John,
Can you please advise how to open the MDAC remote? I've opened the battery cover, removed the single screw beneath it then pried the two plastic sections apart a little but I'm worried if I keep forcing it, I'm going to break something... there's got to be a trick to it.
Thanks in advance.
Cheers,
Bruce
I would like to find the answer to this question as well.
