Chris,
https://dl.dropboxusercontent.com/u/86116171/MDAC2 rear panel conector arrangement.jpg
The top row of connectors is the proposed Digital connector arrangement (you can see the USB B connector above the Balanced headphone output which is mounted on the lower Analogue board).
Maybe I could fit a full sized XLR, but I'd have to use a Mini USB connector - we have already had a few people manage to break the full sized USB connector, I'm not sure I trust an even smaller, possibly more fragile "Mini" version + everyone getting upset about needing a new type USB cable...
I'm open to suggestions...
I can see that the problem is the double row of connectors one above the other.
Out of interest, what's the stacking of the analogue and digital boards?
- difficult to describe this but here goes - Working from the bottom I assume you have:
analogue pcb
analogue components (ie analogue sockets)
digital pcb
digital components (and sockets)
In which case I assume the inter-board spacing determines the maximum height of any connector under the digital pcb
Otherwise you'd only be able to claim any more height if (say) you mouted the digital pcb upside down on the underside of the lid. Even then:
- the height of a usb connector looks to be about the same as (say) a toslink connector, so I'm not sure you'd gain any space
- don't know if it has an adverse effect on rf noise pickup
Apologies if I've not remembered earlier posts and this is what you're already doing.
