Belt is brand new , IPA won’t damage the finish on the sub platter ?Have you cleaned the belt, inner platter and pulley? Only thing i can think of is that someone has cleaned the pulley and left a slippery residue on it. The position of the belt on the pulley is right. Clean everything with IPA or something else that won't leave a residue. Failing that it's possible the motor is not in the right position but I think it would run even if it was.
No. The belt may be new but if the pulley is greasy it's got grease on it now.Belt is brand new , IPA won’t damage the finish on the sub platter ?
Sub platter?Do another video of the platter spinning down with no belt attached
I’ll do that I’ll put a piece of masking tape on the sub platter or something so you can see but for sure it doesn’t rotate for agesNo. The belt may be new but if the pulley is greasy it's got grease on it now.
Check the position of the motor mounting bolts. Usual position is one inward and one outward.
Take the outer platter and belt off. Spin just the inner platter on its own. It should spin very freely and keep spinning for ages.
No the bearing already had oil in it all o did was transport it , here is the link to the bearing rotating. Please note the noise is my phone case not the bearing !!! Well I hope not anyways !!!Have you put any oil in the bearing
