Still waiting for the first pairs to arrive, they have promised faithfully next week, they are based in Rotterdam.
Martijn ( D&D's designer) is a fan of subs but used mainly , I believe to destroy cancellations rather than add extra bass, the 8C's go down to 20Hz on their own .
Keith
Will do, if they ever actually appear!
BW Keith
Looks like they aint coming Keith?
How is your search going otherwise Ken?
KWB1 - from reading your posts I remember you found there has been a lack of the bass you have had previously? The Kii threes etc and others have a flat response. I have a pair of studio headphones that are flat down to very very low frequencies. When I first got them it sounded like there was little bass and I set up a target curve boosting frequencies around 60Hz and below to suit my taste.
What I suggest is you find if there is a graphic equaliser on your computer/sound card and adjust it like I did to achieve the sound you want. I suspect the neutral sound is not enough for those who like bass.
The equaliser looks like this
You would probably want to adjust the 34 and 64 levels, which corresponds to deep bass. The ones to the right is the treble, so if the sound is too piercing/bright you can adjust those.
Note the 34 and 64Hz levels are best handled by a subwoofer sometimes.
they appear stable
I have the app on my IPad and it is fine, if you are going to connect via USB you don't need the app anyway once you have integrated the sub, I would use USB although Bluetooth is useful fort internet radio.
Keith
Hi Mate - Still nothing yet as I was let down by having a home demo of the Focals SM9/Trio6be
For my particular taste in low frequency wobble, I reckon I won’t be entirely happy with just a desktop monitor
I have since ordered a couple of BK Electronics XXLS400 - built to order to handle frequencies below around 60hz
http://www.bkelec.com/hifi/sub_woofers/XXLS400-DF_GW.htm
I was going to pull the trigger on some very capable Kef Ls50 actives that I tried at my place for a few days - they were very very good bar for the lowest octaves
Unfortunately Kef are having trouble with the Wifi App at the moment with people experiencing problems with the wi fi crashing and therefore the speaker/sub settings are not stable - I will wait until I have confirmation that this is now fixed but am keeping my options open
Yes - I use this eq to tame a 30hz peak and to add a little top end with good results
Ken
