chiily
PFM Special Builder
A little bit of progress today. I managed to drill the front baffles, grill frames and tap the hardwood fillets for M8 bolts; everything is pretty straight too. Also cut the slot for the tweeter's tags, not the best free hand router cutting in the world, I'm out of practise. Found that my countersink bit's diameter is less than that of the M8 front bolts, so off to B&Q tomorrow, failing that Amazon.
Gave the cabinets a quick once over with 240 paper and some white spirit before the first wet coat of Danish oil. I've added a couple more very light coats with a rag waiting 15 minutes before wiping off. I'll leave them overnight to fully dry before I add a couple more rag coats, a quick whizz over with wire wool between them to keep it smooth.
I don't have any pictures of progress, just one of the cabinets drying.
PXL_20240302_165456169 by Garf Arf, on Flickr
The bass/mid driver is due next week along with the cross over components.
I plumped for a dark blue for the baffle.
And a light grey for the speaker grill cloth.
