... Could do with a jewellers' loupe though!
I have a magnetic arm lifter, which works well enough, but I still miss the AT one.I've got a similar device to the AT but it's by Goldring and is triangular in shape, pretty sure it does the same thing.
On the AT auto-lift, for only £200 you get get one of these...http://www.littlefwend.com/ or what seems to be a Chinese copy of an i-qual here: http://rover.ebay.com/rover/1/710-5...0001&campid=5338728743&icep_item=282737162012
but myself, I reckon this can be made to work, and a lot more fun, for pennies....https://www.thingiverse.com/thing:2098491
The AT is a great device, I bought mine new way back in the 90s.Just gave my Benz Micro Ace it's first clean with the AT and then gave my Analogue Productions copy of Muddy Waters - Folk Singer a spin
Been using my AT637 more often recently, due to issues of distortion on some records, not all.
I purchased it at least 30 years ago and it's still going strong, I changed the battery earlier as the light was very dim and it also made the pad vibrate more.
Anyway two questions.
I always thought it should be used for a max of 20 seconds as per the original instructions, but a search earlier, including Linn Docs, said 5-7 minutes max. So owners, how long do you leave your stylus on the pad for?
Also is it worth cleaning the pad? I never touched mine in all those years, if yes how do you clean it?
Thanks in anticipation.
Do you ever have issues getting the unit to remain still in operation? If you look at this guy's video (watch from 13min) the vibration makes the device jump around. Perhaps because he's using a hard TT mat?!I’ve seen no credible evidence it does any harm to the cartridge at all, i.e. you should be able to leave it there all week without issue. Any additional fluid is far more of a concern, e.g. the AT stuff that comes with it, Last etc. That really is a variable and likely depends manufacturer to manufacturer. By saying that I have never had any issue with the AT stuff though since moving to a Nagaoka MP-500 which has a tip glued to a boron cantilever I decided to move to Nagaoka’s own fluid just to be on the safe side. I only use a tiny drop on the pad, I don’t apply anything to the stylus. Checking with a nice loupe will give you a good indication of how clean the stylus is and how long it takes to get there. I tend to leave it for a couple of minutes, no more, I often do it when I’m cleaning a new record.
I’ve never done anything more than give the pad a gentle brush with a stylus brush. That’s all it ever needs IME.
