I very much doubt the Caspian will do 60amps.
Why do say think that?
Worse than 1 ohms ! Have a look at the speaker in question. Mini blow torch wouldn't be such a bad name.
1w/2.83v reference point, in the technical summary tables of both products datasheet.
There has been some refinements it seems, and in a resolving enough system, it can definitely be heard.
HX1.2 mk1 = 130 watts
HX1.2 mk2 = 180 watts
The MB100 can deliver almost 200 W/ch and it can deliver that power to any impedance between 1-8 ohm. The power delivery does not change with impedance as the amp is protected against overheating. Current delivery is extremely high, i once connected it by mistake to a copper bridge, and the bridge played the music...
You seem preoccupied with a 2-ohm rating. Your Shahinians might dip that low in the HF, but unless you are playing only HF at ear-piercing levels, your amplifier will be seeing more than 2-ohms on full bandwidth audio.If it says minimum 2ohm, does that mean there is a risk of it cutting out if it dips below?
Hi Teddy, elsewhere on this thread it's been suggested that the power should ideally double for each drop of 2 ohms.
Is it therefore sufficient to be delivering 200watts at 1/2 ohms? Is this only really relevant at very high volumes?
I noticed that without enough current, my speakers would sound less than their best even at low volumes but it was only when you turned it up it became obvious something wasn't right.
Because 60 amps is a massive current. To put that through a transistor amp needs multiple transistors sharing the current and huge heat sinks etc like say a Krell. A Caspian has none of this.
But but but the James Bond transistors in the Naim 300 and 500 are said to be 80A devices rated at 350W each. However I doubt very much if the Caspian has these or anything like them. What confuses me is the said 60A peak to peak. Methinks this is a ruse of 30A in each direction.
I wonder if these Bond transistors are really several in parallel inside the one can?
Cheers,
DV
That seems to imply there was a problem due to the amp having either a high output impedance or a stability problem. As distinct from current limiting.
Hi Teddy, elsewhere on this thread it's been suggested that the power should ideally double for each drop of 2 ohms. Is it therefore sufficient to be delivering 200watts at 1/2 ohms? Is this only really relevant at very high volumes?
Do you think my caspian would suit well as a preamp to the mb100s?
