darkmatter
I have a soft spot for Hiquphon tweeters. I've used the OW-1 and OW-3, but I've also had great results from Seas, Scan-speak and Morel.
My last design entailed a very low XO between woofer and mid (circa 150Hz, actively filtered) to enable the mid to cover the full range of the human voice. But I think asking a mid to go that low compromises mid and upper bass impact. If I were to redesign that again, I'd cross at 300Hz or above. So your instincts on using the 13M from 400Hz upwards accords with my experience, and it's easy enough to use a passive filter without the fs resonance of either driver pair getting in the way.
I'm curious about your choice of 3rd order filters. I've used first, second and third order electrical filters but they are always targeted at even order LR2 or LR4 acoustic transfers. Are you referring to 3rd order acoustic or electrical?
You are getting me itching for another design.
Like you I have had experience with all kinds of filters and drivers, but I selected third order (electrical) filters for this project as the drivers I am considering will likely work best with these. The three ways systems I have built seem to measure better with them. Obviously driver selection will also dictate which filters work best.
One project I built 20 years ago now used just an inductor on the bass a resistor and Capacitor on the tweeter and this was one of the smoothest systems I have ever heard or measured!! Both drivers were from Seas and no longer available, alas.
As an aside and inspired by my love of that design, I may also, again on paper look at an NS1000 type 3 way system, so what drivers for that? I did play with the big Scan but may also go a bit larger to consider what the 15" SB driver would do.
