darkmatter
As an exercise at this stage, I am assessing the possibility of designing a big three way system based upon the Volt RV4564 18" Bass unit.
The bass driver will be used in a large reflex cabinet probably around 300 litres, tuned to around resonance. Their datasheet alludes to this possible alignment.
I might even consider a TL, but that might follow as part of the assessment process.
Selection of midrange drivers and tweeters is next.
Crossover will be passive third order as I like these and prefer modelling with them.
Tweeter is likely to be a top Scanspeak or Seas such as the 29TFF/W H1318 or the high end Crescendo T29 or more likely one of the Seas 35mm domes. As a lower cost I like the Audax TW034X0 which is sensitive enough. I already have these. Equalisation as part of the design process or TL loading will mean the tweeters specified will be a fine match.
Now comes to selection of the midrange.
Crossover point will likely be 300 Hz so this might rule out the big Volt dome unit. So likely to consider a cone unit but which one?
Using a third order APC reverse polarity BP filter means one gets back ~2.5 dbs of bandpass gain so this means that cone units of around 90 d/bw would be a fit.
The Seas MCA15RCY H1262 is a possible fit having a smooth response with minimal work required, it can handle a 300 crossover point fine, it works down to 100 Hz.
So now looking for suitable midrange candidates.
Simon
Simon
