OK, so a week has passed, and I've done some more.
It's fairly mundane and boring stuff, but necessary.
The amplifier packs and the speaker enclosures are on plug and socket connections.
After some digging, I discovered they're ITT Cannon Trident series connectors, which are still manufactured.
That's handy, because with the passage of time and - I think - some rough handling, there's broken latches on a number of the connectors.
I've purchased a quantity of plugs and sockets sufficient to replace all of the original ones.
They're constructed, like most industrial connectors, such that it's possible to disassemble them, removing the pins / receptacles and wires non-destructively. This would allow replacing a damaged pin in the existing housing, or in my case replacing the housings without having to buy new pins and solder them onto the wires.
There's a special tool to efficiently unclip the pins. I've purchased one.
I've done this sort of thing plenty of times before in my work, with all manners of different connectors. It's not particularly difficult or exciting, but from time to time you have to do it.
The sockets on the back of the amps were looking a bit sad:
and had a tendency to fall in when I tried to insert the plugs.
After removing a lot of screws, I was able to lay the rear panel flat on the bench to access the inner side. Helpfully, there was quite a lot of slack in the wiring loom, which made the whole thing a lot easier than it could have been.
I unclipped the sockets one at a time and disassembled them.
Then it was just a case of poking the receptacles into the new housings, ensuring that each one went back in the correct location.
Two of the three sockets on each amp have a blanked-off part, to prevent plugging the mid / tweeter enclosure into a bass amplifier channel. They will unclip (with some effort) and they got transferred across to the new sockets.
Finally, the reassembled sockets snap into place in the rear panels of the amps, and it all goes back together.
The cable plugs come apart similarly to the sockets, with the same tool:
and I replaced the housings on the plugs for the mid / tweeter housings. There were a number where the locking tab / latch had broken on one side. In principle, it probably didn't matter much because the plugs and sockets are a reassuringly tight fit and probably wouldn't have wiggled loose, but the new housings were about £1.50 each and they're all getting replaced.
https://imgur.com/d18vKtG
Partially dismantled plug - the pins have been unclipped and the housing will now just lift off:
https://imgur.com/Eg0eTcc
And then reassembled, with new heatshrink:
Discover the magic of the internet at Imgur, a community powered entertainment destination. Lift your spirits with funny jokes, trending memes, entertaining gifs, inspiring stories, viral videos, and so much more from users like PaulMarchant.
imgur.com
So, I still need to do the connectors for the bass enclosures. This will be another day, as they're over at the Big Yellow Storage place round the corner. I'm rapidly approaching the point where I need to haul all of them around to work, where I'll do the remaining four plugs, flip the drivers through 180 degrees to compensate for gravity sagging them over the years, and glue on two dust-caps. And then make some noise...
This will happen in the not-too-distant future, but will require a second pair of hands and someone with a larger car than mine. I've spoken to a mate who lives fairly close to where this is all taking place, and he's offered to help in a few weeks time.
