Gaius
It's a cable that links a Naim pre to a Naim power.
I have had this on loan from Mark (MJS) for 10 days or so.
Initially I had a quick listen; it makes quite a difference.
I then had Ewen 1970 round here, we have been testing and evaluating so much Naim on the front end of the chain for quite some time; I value his input.
We played some familiar music to us both as a benchmark and swapped cables, this was from a Flashback 4 pin which I find competitive to Naim's own.
Ewen started to smile, after the second number which I think was Numbers by Kraftwerk, he pronounced it a no brainer.
It quite simply did everything better.
Tonight I thought for a thorough test I'd swap back.
I always think that's the best way, A/Bs are not always as conclusive as they seem, I like to live with things for a bit and then see.
In this case, first impressions are bang on, by comparison it made the other sound confused and messy.
This is a nice product from Witchhat, a big step up at little cost.
I'll perhaps do a further write up elaborating on the finer points but in the end I'll agree with Ewen, a very clear no brainer.
