Are you taking the signal to the power amp from the flatcap or the preamp? I found that (inadvertently) taking the signal from my 102 (instead of from the flatcap) was detrimental - something to do with signal grounding, I believe.
I do not know what you mean? The flatcapXS can only connect to the preamp of the NaitXS right?
Having owned a Flatcap 2X with a Nait XS for last 3 years i can assure you it makes a bloody huge difference, and so does a Powerline. What is your source, could be it is just making your amp more transparent and you like less what is upstream. Also, as Mark says, if the flatcap needs a service then it will sound worse than without it. What version of Flatcap is it? Lastly get yourself a Naim or Flashback Snaic before making any conclusions.
Its not the source, i tried two different dacs. Both sound wonderfull without the flatcap. With the flatcap my car stereo sounds way better. witch makes me believe that i am doing something wrong, but i do not know what.
I did a demo at the store with a different system and in that system the flatap was a hugh improvent. They did not allow a home demo and that is reason why i baught the flatcapxs second hand.
