mandryka
This has happened twice over the past month, both times playing spotify.
When the track changes instead of music I get lots of white noise, sometimes loud! If I pause the stream, the noise stops. If I go to the next track, everything is fine. There's no problem with the spotify track if I go back to it. It does not seem to harm any equipment -- but I don't like it!
Any suggestions about how to diagnose it? I've just changed the streamer to another squeezebox. My plan from there was to change the coaxial cable if it occurs again, and then the DAC and so on. Maybe the problem is in the spotify stream, which is through an LMS plugin. That being said, it hasn't happened on any of my other systems, which use the same plugin.
System is "vintage" and complicated -- Squeezebox, Museatex DAC, external crossover to main speakers and subs, Krell KSA50, external Velleman DC protection, ESL63 and Gradients.
