Tony L
Administrator
Thanks for mentioning Servisol; I've just ordered some, to clean some slightly marked equipment. Always worth a try.
Would Autoglym work on the rubber surrounds of older speakers?
On rubber, I suspect so, but not foam - that stuff just needs replacement. I tried a little Autoglym on the rubber surrounds of the B110s of my JR149s and it cleaned them up beautifully cosmetically, they were rather dull and grey looking with a little mould as they had obviously been stored somewhere less than ideal. I ended up replacing them with new Falcon FB110s as the pair matching was obviously too far off spec (I've got their T27s on order for the same reason, they will work out an exceptionally expensive pair of 149s!), but I suspect in many cases a gentle wipe with some Autoglym would help with this type of driver. It just seems to rejuvenate the rubber. The difference it made to the rubber mat of my 1963 Lenco L70 had to be seen to be believed!
