Johnjo
I had similar results with my 15” HPD Tannoys. I found them a bit lean sounding in my room in their original sealed Lockwood cabinets as I like a fat, bass heavyish sound. Fitting the drivers into Arden sized ported cabinets was great but just too much speaker for the room. Cracking open the sealed enclosure slightly around the crossover panel gave the Goldilocks “just right” balance.
The issue is my room rather than the speakers but I found just opening the enclosure enough to take the back pressure off the cone seemed to work wonders. I’m guessing you’ve ended up with a similar result taking the plinths off the Wharfedales.
