Purité Audio
Trade: Purite Audio
The new Weiss IT202 firewire interface has arrived!
I have been listening to it this afternoon with my Stahl-Tek dac and it is a super bit of kit. It allows you to use an older dac (without USB or firewire connections ) and connect it to a Mac or PC through it's async firewire protocol.
It offers technically the best possible connection from your computer to your DAC ( async firewire pretty much totally eliminates interface jitter ), it also comes with a properly dithered digital attenuator and even an optional remote.
So if you only use a PC/Mac as source the INT202 effectively replaces your preamp. The INT202 is probably the ultimate method of connecting your dac to a computer source!
Technical specs are here.
http://www.weiss-highend.ch/int202/index.html
Thanks for your time,Keith.
__________________
www.puriteaudio.co.uk/
__________________
