Cereal Killer
432
The +/- 0.05mm VTA-Team....
Captain Obsession, OCD Boy...
Maybe this sould be in the diy room
......... and their ruler..... Micrometer Man
Literal much?As an inanimate object, surely they are not 'expecting' anything?
So long as its not just the usual on axis response.
The response testing needs to be comprehensive, and you need to include distortion and decay plots to get a reasonable picture.
You can have a loudspeaker with a beautifully flat on axis response but if, as is sometimes the case, severe driver resonances are not adequately attenuated by the crossover because the slope is too shallow (and/or at the wrong frequency) it can sound nasty. So for example, a loudspeaker can sound subjectively bright even though it doesn't have a rising upper mid or top.
With electronics, and I'm thinking pre, power, dac & adc, there is no need to listen at all when choosing. Transparency and therefore fidelity to the input signal can be determined by a few basic measurements.
People only really need to audition electronics if they 'want' something that lacks fidelity.
Either this is a troll or you are speaking rubbish. For years labs have tested equipment and produced those lovely graphs and then they listen. At the end of the day the graphs say very little and often mislead.
Cheers,
DV
S, are you saying all amps don't sound the same????
Just had another thought. I accept we might not have perfect audio components, dont we all? But that shouldnt matter if measurements tell us everything. Here is the example: a mini monitor rolls off at 60Hz, 0.5% distortion at this frequency against a larger monitor that rolls off at 30Hz but with 1% distortion at 30 up to 60Hz. The mini monitor has lower distortion so its closer to perfection. Oh no it isnt because it doesnt reproduce the lower frequencies. (I understand about roll offs and the mini monitor might well be playing at 30Hz but for this example it is below audiability). Isnt the best answer here to use your ears to decide which is the best compromise? Or can you give me the measurement that will decide? A "Sin-of-commission-sin-of-ommission-ometer" please.
There is no such thing as an absolutely transparent and dynamic amplifier that would, for example be capable of reproducing faithfully the transients of drums being played in a small room.
Some amplifiers are more transparent than others. None are absolutely transparent.
