JemHayward
My main system is RPi -> MDAC -> Radford STA25 -> ML Summits, and it works splendidly. One day (maybe) the Radford will be replaced by the Lakewest VFET power amps.
I still, occasionally play LPs, so the main system is complicated by the addition of the TTPSU, the Phono Stage (Naim 5-series boards and Supercap regulators in a DIY box), ADC (Meridian 221), and then I have to use a B Putzeys Balanced volume control, as there isn't enough gain in the LP chain to get decent volumes.
So, it's all a bit complicated...
So, I'm thinking of putting together a vinyl system in the barn where the TV lives, which is a big open space about 9m x 5m, though it is used for TV, exhibitions, guest suite, teenager bedroom (temporary).
The Vinyl system would end up being:
Transcriptors Skeleton, Vestigial Arm, Decca London (various) or Zu ESCO Denon DL103, my Naim based phono stage, or maybe use the Radford SC22 phono stage, SC22 as preamp and STA25 power amp into Quad 57s - basically my dream system from my schooldays. I will continue to use the Quads a the main TV speakers as I do now, with my Linn Sizmik sub, and Meridian M30 active surrounds, my centre is a Fostex single driver (works really well!). Stacked Quads were in the plan, but other half said no 8-(
Has anyone done a complete system split - and if so, do you actually use both (which is my worry).
