On the other hand, pre-amps don't have output transformers...
S.
If a valve amplifier has any character it will be because of the output transformer and the results of limited open-loop bandwidth and the resultant distortions at the frequency extremes. This affects power amplifiers only.
On the other hand, pre-amps don't have output transformers, and their performance as line-level input selectors and volume controllers can easily be transparent and sonically identical to a SS pre-amp. That leaves valve phono stages, which generally, but not always will have more noise than a SS phono stage, but much better headroom.
Overall, my view is that valve amplifiers don't necessarily have a "valve sound", but if they do, then it's due to the power amp.
S.
Serge, that's exactly what I was going to say. There is no point to having valves in a pre-amp.
Louballoo
Louballoo
I know people who run tube preamps with either high-power solid state power amps or active speakers, both with great success. The tube pre brings much of the attributes of a full tube system, plus allows considerable scope for tuning to taste (e.g. a Mullard ECC83 sounds very different to say a Telefunken or RCA) - it gives the tube sound without losing the ability to drive awkward or demanding speakers. I've never seen the appeal of doing it the other way round, e.g. solid state pre & tube power.
I think someone has been reading Stereophile again...................
My valve power amp measures flat from 5 to 100,000 Hz.
There's always one........
S.
More than one, actually....
EAR, Audionote, Shindo etc.
Just goes to show, generalisations "pre-amps don't have output transformers" are fine until they aren't=)
