Dougie2404
cranky old git
Yeh , mine was the same Rock Grott mods with,,,,,no I don't remember if the valves were changed or not 6922's I think r maybe ecc83's but I'm guessing.
i used a music fidelity x D10 between my cdx and prep. it improved the edginees of the cdx somewhat, not completely though. tge cdx was still pretty shrill
Controversial subject, especially when it comes to Chinese ones, but let me tell you, it works a treat.
Adds weight, scale, sweetness (smoothness?) to any system.
Fantastic build quality with a precision aluminium machined case and rastered pots which would probably embarrass some more 'enthusiast' units at twenty times the price. - Not for the willy waving audiophile though for which size/weight equates to quality as this thing is minute.
Even if you question the technical aspects of this thing, look at it as a lovely tone control for a system that could do with a little glow, going beyond what mere bass and treble controls usually do.
Cost? A cheap meal for two!
The truth is that you were masking the shrillness somewhat whilst reducing channel separation, adding a bit of harmonic distortion and raising the noise-floor when you should have addressed the cause of the shrillness in the first place, by replacing the CD player for a better unit, but making sure that it wasn't the amplifier or the speakers causing the problem.
There is a lot of good information in this thread. I bought one, but unfortunately short-lived in my system...
I bought: https://www.amazon.co.uk/dp/B071VSTDQY/?tag=pinkfishmedia-21 a few months ago as a fun purchase to put between my Tisbury Domino head amp and Quad 306. Results were amazing: not only did the sound have more body compared to the Tisbury passive previously used, but fascinatingly, I felt that as well as more PRAT, the system 'phrased' better - the different musical threads made more sense, as if they were talking to each other. A CD of Les Quatuor Mosaiqes was a revelation, suddenly I realised the fascination some folk have for string quartets, truly delicious to hear. So this is the valve sound eh? Here to stay!
Er no. Turning on the device one day I heard a crackle. I touched the volume control to hear a bang through loudspeakers, touching the case made another one! Pressing the off button on the Quad 306 made a truly frightening noise, before the system thankfully fell quiet. I tried the Nobsound with my Class D amp with the same effect. Swapping the power supply gave short term relief, but a nasty fizz from the system reminded me of the fallacy of wishful thinking. I hastily turned it off, and swapped the Tisbury Passive back in.
While the Nobsound was in the system, it was one of the best - and good value - changes I've made. It was truly musical. I would gladly try it again, but I lack the skills to take the device apart and find the issue that makes it, for me, a poisoned chalice. I think I will think carefully before buying Chinese cheapy hifi again!
Good luck to the OP, hope your pleasure lasts longer than mine!
I always turn my valve kit off when I've finished using it. I mostly turn off the solid state stuff too, though do tend to leave the Naim system on - just because there are so many components to turn off.
After a bit more listening I've removed it from the system. It didn't complete destroy the sound but has added a bit of vagueness and my system is noticeably better without it.
Well, you scratched that itch ...
Good point. I did replace the cdx with a mac book pro that left the CDX for dead in some ways (listenability being the most important)The truth is that you were masking the shrillness somewhat whilst reducing channel separation, adding a bit of harmonic distortion and raising the noise-floor when you should have addressed the cause of the shrillness in the first place, by replacing the CD player for a better unit, but making sure that it wasn't the amplifier or the speakers causing the problem.
