Hmm... I don't think I'm a fan of JR149 mk1's and SETs, - it emphasises characteristics I'd prefer weren't emphasised, namely forward mids and rolled-off highs.
Note: Ignore the huge drop in bass output below 100Hz, this purely due to my laziness in speaker and mic placement. I didn't bother moving my Dittons out of the room so the JR149s are plonked in front of them more than two feet from the front wall and the mic is still 40% away from the back wall so the poor JRs are getting very little bass support in the measurements. When I did my listening I was sitting two feet closer to the rear wall so I was hearing more bass than the measurements suggest!
On the 8Ω tap the mids are so strong I find it difficult to focus on other aspects of the presentation. The tonal balance improves on the 4Ω tap and is much closer to what I hear through my Yamaha.
I can't say I notice a reduction in control or dynamics when I switch from the 8Ω tap to the 4Ω tap, but this may be because the mids are so prominent on the 8Ω tap that I wrongly perceive the 8Ω tap's presentation as less dynamic to begin with? I can perhaps hear a very slight fuzziness to the sound on the 4Ω tap, but I could just be imagining this. Nothing sounds obviously wrong or lifeless. I'd need to create EQ presets for both taps so that I have a level a playing field in terms of frequency response which would allow me to focus on assessing the dynamics.
The REW measurements show no statistically significant differences in THD between the 8Ω and 4Ω taps, but I'd need to run the tests at much higher SPLs in order to drown out the external noise pollution for more reliable results.
I should also qualify my findings by noting that the JR149s used for these tests are completely original and that the forward mids and rolled-off highs could at least be in part due to the drivers and/or crossovers drifting off-spec. I ought to refurbish them but I've always got too many other projects on the go!...
EDIT - A note about the effect of output impedance on the bass response.
This JR149 impedance plot shows an impedance of 10Ω at 200Hz that gradually rises to 16Ω at 100Hz and shoots all the way up to 60Ω at 60Hz, yet the boost I'm measuring at 60Hz is only +1dB higher than the boost at 100Hz. If an increase in impedance from 10Ω to 16Ω causes an increase of +1dB, shouldn't an increase from 10Ω to 60Ω cause a much higher increase than +2dB?
