john dolan
Can he be used as a remote control to play records I wonder.
It can do anything: deus intra machina.
(in case this is still relevant)What I find difficult to understand is why anybody bothers with any other transfer protocol other than TCP/IP.
I have put this question to the forum on a few occasions, and never received an answer, let alone a satisfactory one.
Chris
Getting back on topic - on the XXHighEnd forum over the last six months, there has been a little flurry of interesting activity re: modifying PCIe cards for USB. In particular the Silverstone card has received attention. Perhaps someone could spare £9.50 for a trial? Does it sound the same as your motherboard output?
A locally generated clock (like the one in a DAC with the input buffer scheme as described) of course can be contaminated with (asynchronous) signals. Such a sampling clock has to be considered to be an analog signal and thus is prone to all kinds of "contamination mechanisms". But it is simpler to keep a locally generated clock clean than to regenerate a low jitter clock from a jittery input clock.
Same with DACs with an async USB interface. The async scheme is a good idea, but it has to be properly implemented.
Daniel
Daniel: Can I get your response to the fact that a significant number of owners find your DACs not to be impervious?
I've personally heard at least three Weiss Firewire DACs in customers' homes that the customer believed clearly discriminated between Firewire sources. We've sold several Mac Minis and many Firewire cables to customers after extended home loans who are convinced they make their DAC sound better.
Rafael Todes chose Weiss DACs specifically in his review of SPDIF converters, and was able to map audible differences between them. Later, he used the same converter to review differences between Firewire cables and computers.
In the Antipodes audio link referred to above, there are several users talking about differences between sources into the Weiss. I could go on . . . but you get the picture!
Clearly one of the design goals of a DAC is to level such differences as far as possible, but many designers (like John Westlake) are sanguine about the difficulty of making universal predictions in this area - while not being unaware of the possibility that users are simply kidding themselves. Other actively embrace the idea that the transport and digital cabling may well play an active role in the performance of the source, however the DAC is designed
And your product range seems to speak volubly in support of that idea - with some very thoroughly engineered - and expensive - digital transports and cables.
But how do you respond to customers who do not find their Weiss DACs to be immune to upstream factors? The customer is always right? Or not?
As you may know, I take the view that a DAC being susceptible in this way is absolutely no discredit to it. However, you should be warned that some on this forum will view such an admission as a confession of failure. And a rather strict interpretation of 'bits are bits' is proselytised by some Weiss dealers in the UK.
