Then i think: How about, for a belt drive turntable, a paddle that sticks out to the side of the platter, said paddle 'rowing' over a pool of viscous fluid? Fluid damping... for the turntable itself !!
In any case it wouldn't be extremely difficult to implement if the paddle is close to the tonearm bearing shaft, and the viscous fluid well is a donut around the bearing...
John, when I try the same thing with my Kuzdek it makes two full L_R cycles and returns to its starting position. I load it just short of the point at which the belt slips.
the deck I uploaded from is a Micro Seiki SX8000 which has a very substantial platter, I think an air bearing and a dc servo controlled motor with a heavyweight flywheel as far as I know. The quality of the test record is an unknown.
Well, I think the explanation of the spikes I have are no way mechanical of cyclical in nature as I do not hear it on record but only on digital copy. The file is located here you can clearly hear the event with open ear:Romy, it looks to be a little noisy which we can assume is the data capture and record surface noise, we can discount that from an assessment. It's not perfectly round which means either the record is poorly pressed or there's an issue with the PSU control, belt, bearing etc.
The fact that the errors overlay each other with remarkable accuracy from one revolution of the platter to the next would imply that any error is cyclical in nature and occurs on the record, platter, bearing, as the errors seem to be at perfect multiple of the platter rotation speed.
I have no idea what the 5 spikes are, I'm sure Paul will come up with a suggestion. But discounting all of the above and blaming them on the most likely culprit- the record, I think it's a very good result. The similarities from one revolution to the next are quite remarkable.
OK, I just look into the problem again. I discover that with all my intention to run my Pacific A/D in master mode the Lynx card that interface between my A/D and my PC was set to run from internal clock. So, I fixed the problem and resent Lynx to run from external clock and make Pacific to be a master clock. So, my former test with two separate master clocks has to be discarded.Beside my interest to submit a test file that will not be compromised (and it is something that I would like to do) I keep sinking what might make this noise on digital level. It is remotely possible that the second has some kind UHF noise that in some way interferes with my A/D, creating the spikes and THAT what I would like to investigate as I did not see it before.
Why would critical damping of the belt/platter resonance be a good idea?
Paul
Of course.As with a lot of things on a turntable, you have numerous contradictions that need to be balanced.
I wonder how much of a simplification treating the belt/platter as a resonant system is, the motor has a modest mass and a substantial electrical 'elasticity'. It might be interesting to add some dragginess at the motor spindle. Or some inertia.
That's why it's fun to think about it and ask questions.
Werner, you were looking at a DC motor though, we're talking about an AC sync motor that doesn't droop in relation to load, a different fish entirely- surely?
