Edd, thank you!
Wow, what a difference! The idler must have been working against the notorious
fiber washer (the one with the pin), producing the fast tik-tik-tik sound I could hear with
a more advanced arm-cart than the stock EMT.
Edd, do you also have the demodulated spectra? Would be interesting to see how much is the 2.72Hz peak attenauted by the teflon washer.
BTW, the difference between my files 1) and 2) lies not in any foil--both 1) and 2) were taken with the same teflon foil washer in place. The only difference is a nearby fridge beeing switched on (track 1) and off (2)...
) The deck was out of its console so it was sensitive to all vibrations and I did not remember if when taking the standard 3) the fridge was on or off
...but the difference is so obvious that it doesn't matter.
Your file looks very smooth=absence of flutter? But the shape is more oval, could it be the test LP eccentricity?
Good job guys and thanks lencoheaven Dimitri for the tip!
PS Edd, I presume your scale is different than Paul's as my standard polar plot did not look that ugly (red trace):
http://www.pinkfishmedia.net/forum/showpost.php?p=1788378&postcount=341
or something else has happened?
