JemHayward
My Transcriptors Skeleton uses the Papst AC motor that was used on the earlier, AC Gyrodeks, with a custom made pulley which allows me to run the motor at lower RPM, which reduces vibration quite notably, and my (Meldano) TTPSU allows me to alter the phase as weel, so I'm pretty confident I have the motor producing the minimum possible vibration. However, the Skeleton is basically a glass box, so I can hear some motor noise if I connect the motor rigidly to the glass box. If I suspend the motor using O-rings, it's completely silent, but it's a PITA to get the belt running properly as the motor refuses to sit straight, and I do wonder if the noise is not coming out, is it being transmitted to the platter via the belt.
I want to build a motor mounting system that will allow me to control the motor position more precisely, and allow the levelling of the motor, and silent running - wondering what the best method would be.
Any ideas or opinions?
