Im based in SE London and need to get my 3 TTs serviced and repaired as they have been rather neglected for a while.
The turntables that require servicing are:
Planar 3
X 2 Technics 1210s
I'm sure I could do it all myself, however time constraints won't allow me too at present. So with this in mind I wondered which dealer you would recommend and which dealer charges reasonable prices.
Furthermore two TTs have issues apart from needing a service which are:
Planar 3: Platter not turning, I believe this to be a motor issue as the motor seems to be vibrating from side to side without spinning the belt, thus platter not spinning. I'm unsure as to what else it could be but any advice greatly appreciated.
Technics 1210: the left channel has gone. I have checked all connections externally and could only assume it maybe an internal issue. I also swapped carts to make sure the cart was not faulty. Again any advice greatly appreciated.
Although I have mentioned dealers, if anyone is keen on taking this on themselves, I would be happy to pay a reasonable price for their time. Local londoners would be preferred however am also willing to drive further afield.
Finally I feel that many items of the service and repairs, are probably bits and pieces that I could buy beforehand to save further money. Is it worth my while possibly buying the following?
Planar 3: New belt, motor and bearing oil?
Technics 1210s: New bearing oil?
As you will probably gather I have never serviced a TT, however I am prepared to give it a go, subject to time, if members feel it would save money, teach me something that will assist in the long run and get my TTs back to full health!
I feel confident that I could probably service the planar however it is the Technics that concerns me more! Plus would I be able to do the required repairs!
So dealer, a member or me doing it personally, any help regarding this I'd be most grateful for!
Planar 3
X 2 Technics 1210s
